Hi
1st
\o/
2nd
\o/
3rd
These are 3 error messages that appear whenever I try to use TMPGEnc Plus 2.5.
Really they are starting to piss me off. Like they appear whenever I try to convert a simple *.avi file. The big problem is that the error messages state something I can't repare, or at least I don't know how.
I just don't know what to do. It was working so fine
ty,
Tiago Cabaço.
insc,
https://www.videohelp.com/tmpgenc#problems
Second one down.
This is the wrong forum to post this in - you'd get a lot more views/advice if you posted this kind of question in "Newbie Conversion".
You'd also see a big blue topic at the top by Baldrick that reads "TMPGEnc problems and tips", which is where I found the answer. Any other TMPGEnc troubles, you'd probably save yourself a bit of time and trouble checking there/searching the forums first.
Anyway, I hope this helps!
CobraDMX
MPEG4 subtitles
By miconba in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 00:11 -
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
unknown file
By nicgrosso in forum ffmpegX general discussionReplies: 27Last Post: 7th Apr 2008, 14:20 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
