Hi Everyone.
I am looking to convert vcd to dvd if possible if so any help would be appreciated.
Please look in the guides before asking questions.
https://www.videohelp.com/guides.php?guideid=26&howtoselect=3;29#26
https://www.videohelp.com/guides.php?guideid=436&howtoselect=3;29#436 -
I have recently just started to do this myself. With good success.
I used ISObuster to extract the MPEG from the VCD. Then TMPG DVD Author which converts the audio from 44.1K to 48K which is needed for DVD. And Burn with NERO 6.
I left the video as mpg 1. I figured I couldn't improve the video so why bother converting to MPG2. Which also gives the advantage of being able to easily fit 3 movies onto 1 DVD-R if I wanted to.
TMPGenc easily joins MPGs if a VCD is on 2 CDRs. -
ISO Buster isn't needed,TDA will author directly from the .dat file and will convert the audio to DVD compliant 48000. VCD's 352x240 is DVD legal.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 16th Jun 2010, 23:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 10:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 19:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 06:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
