Any help with this? I had a generic DVD-Rom drive, and an LG-4040B burner. The burner was burning Ritek -R G04's at 4X with no problems. I decided to get the Lite On XJ-HD166S because I wanted to increase my ripping speed for DVD backing purposes. After installing the Lite On, my ripping speeds increased MASSIVELY.......BUT, my BURNING speeds have DECREASED! Now, when I burn on Ritek G04's, they will not burn any faster than 2x. This was not an issue when I had the generic burner in place of the Lite On. Anybody know how I can fix this problem so I can burn at 4x again? ANY help would be appreciated!
Results 1 to 9 of 9
A few things to check -
Burner as Master, ripper as slave
DMA is still on the burner ?
See if those two ideas help. If not, post back -
Originally Posted by jtommyj
Right click on the MY COMPUTER icon. Go down to properties and left click.
Go to HARDWARE then DEVICE MANAGER-
Click on the IDE CONTROLLERS and expand them.
Go to PRIMARY or SECONDARY.
Click on properties, ADVANCED SETTINGS and set to DMA if AVAILABLE.
REBOOT -
P.S. Thanks JTommyJ for getting back to me and trying to help me out with this issue.....
http://pub173.ezboard.com/funofficialsonyfrm39.showMessage?topicID=335.topic -
THAT was my next suggestion. I've seen that work before also.
Glad you got it hooked up.
Tom -
I had a similar problem...XP decided to switch my DVD ROM drive to PIO from UDMA Mode2 while my dvd burner on the same Secondary IDE channel remained at UDMA Mode 2. Uninstalling the Secondary IDE channel, then scanning for hardware changes or rebooting would reset the ROM drive to UDMA mode 2 for a while, maybe reading 1/2 of a disk. Then out of nowhere, XP switched the ROM back to PIO.
I did a Google search and found out that when XP has trouble reading a disk, it may switch the drive to PIO mode. I ran a disk cleaner and the problem disappeared.
Hope this helps someone cuz PIO mode really sux. -
Originally Posted by half_track
Adding controls to a swf (then adding to website)
By AshleyQuick in forum Newbie / General discussionsReplies: 6Last Post: 14th Oct 2011, 03:02 -
New Lite-on drive being recognized as old lite-on drive
By tlrbjc in forum DVD & Blu-ray WritersReplies: 2Last Post: 23rd Jun 2010, 08:21 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 13:54 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 13:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 03:23
