I just purchased the DV-RW2...it's a pretty good unit except I am having problems playing the DVD-R's on my Sharp DV-710 set top player. Playback video and audio is choppy. I have tried burning in all quality formats with the same results in the other set top. I do have success playing burned movies from my pc (using a Pioneer drive) on the DV-710 set top unit. I have used Verbatim and CompUSA media.
Anyone know why my setup unit works fine w/ media created on my pc but not with DV-RW2 ?
Have you tried playing Hollywood-made DVDs on the DV-RW2? See if they play choppily (is choppily a word?). If they also play badly, it could be something simple like the laser lens has dust on it and needs cleaned.
I believe that what you are experiencing is common issue with DVD Recorders and compatibility with some players. Best way to overcome this issue is record to rewritable media and re-author on PC. There was one post that I started anout same issue with Panasonic E30.
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
I use the excellent Sharp DV-RW2.Originally Posted by ferny
Never had any problem with it. All my recorded DVDs play well on my standalone Toshiba SD-2710 set top recorder. I think that your problem is about your player. Try other set top players. You should have an answer.
I also use Memorex DVD-Rs without any problem. Try a different brand of DVD-R than the one you use presently.
Yvon
N 45° 31' .949" L 73° 41' .047" -
Your player may have problems playing some media as is indicated here.
https://www.videohelp.com/dvdplayers.php?DVDnameid=383&Search=Search&#comments
Try playing a disc in a friends player or take it to a store and try it on several players to be sure.
Problem recording with Toshiba D-RW2
By polesel31 in forum DVD & Blu-ray RecordersReplies: 22Last Post: 10th Sep 2011, 20:44 -
"Sharp BD-HP21S" - Upscaling problems
By hoklik2 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2011, 08:32 -
Sharp lc-40lb700x
By Margot in forum Newbie / General discussionsReplies: 0Last Post: 8th Jun 2010, 05:16 -
Sharp DV-RW370
By alduz in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Mar 2010, 02:24 -
sharp dv-sv90
By tatusik in forum DVD & Blu-ray PlayersReplies: 1Last Post: 3rd Mar 2008, 11:02
