Hey All,
I was just finishing a project in Adobe Encore. In it's output of it's creation of my a_ts and v_ts dir's, it says it's compatability is good for "Pc Based Software DVD Players"
Is there anywhere that nayone may know of where I need to adjust it to Stand-Alone or Set Top Players ? Or should this even matter ?
As always thank you very much for all your help![]()
~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
On the ADOBE FORUM they say thats a BOGUS CHECK MARK BOX
SETTOP COMPATIBILITY is ensured by standard DVD architecture
this is the forum where Ruud Blaw had a comment on that box that I can't find any more
http://www.adobeforums.com/cgi-bin/webx?14@106.zWB4blrgZDR.1177@.2ccf0ffb -
Thank you very much dcsos
I had thought the same, but was unsure obviously.
I thought there'd be no way for a stand alone to "need" a different type of structure in the a/v_ts dir's.
Before i burned out a bunch of copies of this I wanted to try to get some of it clarified.
Unfortuantely the link only gets me to a login, but if you say it's bogus, and notto worry of, then all is cool
~~~Spidey~~~
Well technically your set-top isn't going to read the _TS folders as they are, they still need to be burned to disc
Tho' Spidey, the forums are full of NAY SAYERS to the ABOBE BURN ENGINE
the experts seeem to prefer building to HARRDDISK and then using the THIRD PARTY APP that knows your burner best to do the rest of the job!
they say the burn engine is quirky, expecially on MULTIPLE burns..(like it errors when you burn more than one, on the second disc) -
Yeah, I use DVD Decrypter for one-off discs and Nero for burns to all of my burners at once when there is call for it. The former tends to give me more compatable burns, though most newer prog. scan players can play most anything, especially the region free ones.
Adobe Encore DVD and subtitles ...
By Liru in forum Authoring (DVD)Replies: 17Last Post: 14th Oct 2010, 17:05 -
Need an Adobe Encore DVD Guru for this one....
By sdsumike619 in forum Authoring (DVD)Replies: 2Last Post: 9th May 2008, 20:24 -
Anyone awake? Need quick help with Encore DVD, re ROM folder
By sdsumike619 in forum Authoring (DVD)Replies: 4Last Post: 9th May 2008, 04:04 -
Problem in Adobe Encore DVD
By zombie_chan in forum Authoring (DVD)Replies: 10Last Post: 24th Apr 2008, 01:09 -
Adobe Encore 2.0 DVD Menu
By ozab in forum Authoring (DVD)Replies: 0Last Post: 13th Aug 2007, 17:03
