Just started playing with windvdcreator and have a question. I have a simple ATI tvwonder- ve capture card. I record all of my tv in mpg1 format, as if I try to raise the quality, the pic sucks. But I'm ok with the vcd quality. My ? is, using windvd creator, when I go to create the dvd files, it ask if I want one hour high or best quality,etc,2 hrs, etc? An example is I want to record superbowl, which is 4 hrs long. What dvd setting should I choose? The media is the tdk[ricoh] 4.7gb.
Thanks...Rip
one more ? I've noticed that using tmpgenc dvd, the only change in output is audio. Does this mean only vcd compatible players will recognize the disk?
