I'm authoring DVDs.
I'm:
-Capturing with ScenalyzerLive via firewire through my camcorder.
-Ripping the audio into .wav with VirtualDub.
-Using VirtualDub's info function to determine the number of frames.
-Converting to .ac3 with ffmpeggui @ 192kbps
-Calculating my bitrate with cceguesser.
-Frameserving the .avi to CCE with AviSynth using a 2 pass VBR.
-Authoring with TMPGEnc DVD Author.
According to cceguesser, with 181570 frames, using Multi-Pass VBR and an audio size (ac3) of 141993 KB, I should be using an average bitrate of 5858kbps to fit on a single layer DVD. The video is around 1 hour 42 minutes long.
The problem is, when I go to "create a DVD folder" with TMPGEnc DVD Author I always get this message:
"The combined bitrate of the clip exceeds the upper limit for a standard DVD.
The current bitrate is video: 9800kbps, audio: 192kbps, combined: 9992kbps.
The combined video and audio bitrate can be no more than 9.848Mbps (9848kbps)."
What am I doing wrong? Should I be calculating the bitrate based on the .wav filesize, not after it's converted to .ac3?
Thanks,
CF
Uncheck the dvd compliant option in CCE.
Read:
https://www.videohelp.com/forum/viewtopic.php?p=787889&highlight=cce+dvd+compliant#787889
Need Help With Deciding on Bitrates
By W1nks in forum Video ConversionReplies: 12Last Post: 6th Dec 2011, 10:17 -
WD TV reccomended bitrates
By SCDVD in forum Newbie / General discussionsReplies: 3Last Post: 1st Nov 2009, 23:20 -
I need some help understanding bitrates...
By pwhyles in forum Newbie / General discussionsReplies: 1Last Post: 7th Apr 2008, 13:54 -
Formulas used to calculate bitrates.
By ziggy1971 in forum Newbie / General discussionsReplies: 16Last Post: 6th Oct 2007, 02:00 -
MP3 Bitrates..
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 23rd Aug 2007, 21:50
