When converting a movie from Divx-Pro 5.1 with a frame size of 640-272 (letterbox) in PAL to VCD MPG, I can get part 1 to convert to the same frame size, but part 2 comes out to have a frame size of 352-240 ( in PAL) which is cropped & looks terrible on the TV.
I have tried frame rates of 29,970, 23,970 & 25,000, with the same result.
I am using VirtualDub & TMPGEnc.
This problem occures only rarely, but thus far I have not been able to overcome it in these instances.
I have been following the Divx to VCD MPEG All-In-One-Guide to the letter.
I know this must be a simple settings error, but after re-encoding this movie 3 times - I refuse to give-up.
I am not a newbee, but I feel like one.
Can anyone clue me in?
tommyrex@comcast.net![]()
I am splitting the file into 2 parts because I am burning them to CD-R disks, and each disk capacity is a maximum of 700 mg.
The result is that the movie is split into part 1 on one disk and part 2 on the second disk. I then can watch the movie on my DVD player that has VCD capability.
Tommyrex -
the only thing that comes to mind right off is check to make sure you set TMPGEnc to full screen (preserve aspect ratio) for both clips you are encoding.
Premiere Pro: Import/Export XviD & Frame Size Issues
By Cube11 in forum EditingReplies: 11Last Post: 6th Feb 2015, 21:43 -
Output Size of PAL VCD Rendered In Sony Vegas Pro 10 Is Too Huge
By LeHuoXuan in forum Authoring (VCD/SVCD)Replies: 8Last Post: 28th Feb 2011, 22:40 -
Converting Divx-AVI to MP4 - Output size option doesn't work
By tomzero in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2010, 08:30 -
AVC conversion, Widescreen frame size, editing with Prem Pro CS3
By Soul_Survivor in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 09:44 -
Good file size when converting TV DVD eps to Xvid/DivX
By ryangarfield in forum DVD RippingReplies: 1Last Post: 28th Apr 2009, 11:06
