  1. hi
    anyone know where i can get some free karaoke software to play cdg? or cdi is it umm
    spadger
  2. cant get it to run
    does this only work in dos
    any more plzz
  3. I've personally never tried it, i never had a reason to. I just took a look at the readme file that goes with it, and it says DOS or Win9x only.
    "It now supports SCSI drives through the ASPI drivers, ATAPI drives
    through the ASPI drivers in Windows 95/98, and ATAPI drives through the
    ATASPI drivers. It will not work under Windows NT or 2000."
    I'm pretty sure you also need a CD-Rom capable of reading the media.
    Nero Info Tool:
    http://www.cdspeed2000.com/files/NeroInfoTool_207.zip
    This utility requires ASPI layer to run!
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
