I`ve been trying to burn back-ups of my xbox software with little sucsess.
I`m using the following hardware/software.
I have an Xbox with the Philips drive.
A Lite-on LDW 4516 DVD drive with the latest b6 firmware.
Nero 6 (but also have Alcohol 120,clone dvd and copy to dvd) prefer to use Nero 6
Datasafe media -r * 4 (ritek)
I`ve copied xbox games but the xbox drive will load about 20% of the time.They seem to load better when
the xbox has been in use (ie warmed up) on genuine non-copy titles.
The xbox ALWAYS loads original titles so its obviously something to do with the copies.
I think its mainly a compatible media problem but I chose the DATASAFE -r (ritek) disks because they seemed
a good console choice.
Does anybody know which PHILIPS drive the XBOX uses and then maybe I can find suitable media for it.
Should I try using dvd+r`s or recording at as slow a speed as possible?
Sorry to ramble on a bit... this is my first post...but it could cost me a fortune in blank media trying to find a
suitable one.
sorry if this is in wrong section.
Any help please.
Cheers
i think its mainly a media problem ive had no troubles with princo media in my xbox with a phillips drive maybe you shoud try that
Welcome to the REAL world! -
Is BULKPAQ Orange a princo disc?
Are you using NERO?
If so are you do a straight Disc to Disc copy?
Cheers! -
i think they are princos yes check the id using dvdinfo pro
i read them in through dvddecrypter using the iso tool and then burn with nero using the recorder -> burn image optionWelcome to the REAL world! -
Are you trying to do games or dvds? I don't get it. If dvds you have to select force xbox compatibility mode in Nero. Use the rright media for your writer.
You cannot copy xbox games *directly* they are in Xfat format.
"Is BULKPAQ Orange a princo disc? "
We call those Bulkcrap as they have no quality control. Get some decent media & save yourself hours of time just trying to save a few pennies. -
I`m trying to back up games that are already `copied`.
Basically because there not totally reliable at loading.
Most are on Bulkpaq Orange or Datawrite Classic(yellow).
Is Nero the `best` copying software(for my purposes) or would you recommend something else?
I`m not using the XBOX at all for DVD films.Although I have succesfully
backed up Dvd`s using DVDSHRINK.
Cheers -
you need create a proper iso use craxtion, nero uses a off set UDF format, also use dvd-r's stay away from +r's. check out xbox-scene.com forums and read the guides. also make sure your xbox clock is set to the correct time and date and not the system zero time. titles like GTA wont load when your date time has been reset.
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 02:05 -
having troubles muxing to a compliant Xbox 360 MP4 file
By deltaboy in forum Video ConversionReplies: 2Last Post: 29th Jun 2010, 12:54 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 06:19 -
TV Out Troubles.
By SE14man in forum Newbie / General discussionsReplies: 54Last Post: 11th Oct 2007, 16:55 -
Backup PS/XBox games?
By bad57 in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2007, 03:11
