Hi all
I am near nervous breakdown stage here due to audio synching problems. I am converting vcd to dvd compliant mpeg using tmpgenc. Most films I am converting are ntsc so I use ntsc mp2 audio. It seems however touch and go whether they are sync or not. What i want is a way to make sure this never happens at all (everything in sync). Would I be better to demux, encode the 2 streams separately and then remux, or what?
VCD video is DVD compliant. You'd be better off leaving it alone and authoring the mpeg while only re-sampling the audio to 48 KHz. Here's a guide.
"Art is making something out of nothing and selling it." - Frank Zappa -
Yeah, I thought about that but when I try to enter the mpegs into tmpgenc dvd author, I get the following message - the video sequence header is incorrect (gop) etc etc.........I cant ignore it either.......is there a way to patch this so it is acceptable?
Did you follow my link to the guide? There's a note about that in there, if you still have problems then maybe ask Lordsmurf at his site.Originally Posted by garvey100"Art is making something out of nothing and selling it." - Frank Zappa
Audio sync probs
By just_kim_usa in forum Video ConversionReplies: 2Last Post: 27th Jan 2011, 14:23 -
DVD FLICK audio sync probs
By dalek7 in forum Authoring (DVD)Replies: 2Last Post: 19th Aug 2010, 02:14 -
video and audio sync probs
By reynardthefox in forum Newbie / General discussionsReplies: 3Last Post: 3rd Mar 2010, 00:23 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35 -
dvdx sync probs
By zookeeper525 in forum DVD RippingReplies: 0Last Post: 17th Aug 2007, 20:29
