I'm trying to capture only audio from a digital video source. So far the way I've been doing it is to capture the video & audio together then use TMPGEnc to separate the video & audio when it encodes. I'm sure there must be a better way ? Any help please.
Closed Thread
Use the RCA left and right output from your cam. You will need a y-adapter that has the male RCA connectors on one end and a female 1/8" stereo headphone connector on the other. You will also need an audio connector that has a 1/8" male stereo headphone plug on each end. One end goes into the y-adapter coming out of your cam and the other end goes into your PC's soundcard auxilliary input. Both the cables can be found at Radio Shack for around $5. Then use any software that allows you to record from your soundcard's input such as Cool Edit Pro/Adobe Audition.
Yea, what Teegee said.
Although I do the same thing as you do, I capture the audio and video together but I use Sonic Foundry or CoolEdit 2000 to get just the audio, that way I have the option of output formats, I usually only want wav or mp3.
Save as DV, open in Virtualdub and select 'save wav'.
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have.
please don't cross post.
https://www.videohelp.com/forum/viewtopic.php?t=203345
Virtual Dub say's No audio decompressor to decompress source audio
By s_joy09 in forum Newbie / General discussionsReplies: 10Last Post: 25th Dec 2011, 15:03 -
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 23:59 -
No audio decompressor could be found to decompress the source audio format.
By rocky12 in forum AudioReplies: 3Last Post: 1st Sep 2008, 01:59 -
ffmpeg -- encoding while muxing new audio w/out source's audio, how ?
By vhelp in forum AudioReplies: 8Last Post: 21st Nov 2007, 20:53 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
