OK, after taking peoples advice and using VirtualDub, TMPGEnv & Author, things seem to be going ok (thankyou to those people), but I have a few questions.
1. When would I use Direct or Full processing.
2. If I have a Divx Ac3.avi, what tool can I use, as I've installed the ac3 plugin and set VirtualDub to direct, but this causes TMPGEnv to lockup when try to convert audio file.
3. When launching Virtual dub, I've had the prompt about incompatible VBR, but ignored it and things have worked fine, was that just luck.
4. If I have a Divx.avi which has 23fps, what do I need to do get this to correct fps (25), I see there are some options in VirtualDub, but with a warning below the option.
Cheers
Mark
1. direct stream copy=it will just copy the audio with no conversion, full processing=it will convert the audio to the compression format you choosed under audio->compression, by defaul wav/pcm
2. https://www.videohelp.com/convert#447
3. read the errror msg, you will only get audio sync problems if you use direct stream copy.
4. https://www.videohelp.com/forum/userguides/78178.php , only convert the video with tmpgenc to 25 fps,be sure to set Do not frame convert under advanced and convert the audio with besweet, set 23,976 to 25. -
Cheers for that, anything I can do to make the final authoring better quality, like tweeking any settings in VirtualDub or TMP, audio always sounds fine, picture can sometimes be a little blocky, original files are crisp and clear.
Mark -
You can always try lower the resolution, like using 352x580/576.
Baldrick, I normally load one of the default templates, would I need to go through it manually in TMP by making a note of all template settings, then just changing the resolution.
Cheers
Mark
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
