Hello, im new to these forums i really what you have got going on here![]()
I have a few question so just sit tight
anyway im having trouble with burning a Vcd in Nero5.5, i will try to add a mpg file to the list and it wont work.? i have taken screen shots to show u what i mean, any help would be great!
- that is what happens when i add try to add the file,
- this what happens when i try to play the file in windows media player, it will play the file but it sends the prompt message
-this is what should happen when i add an mpg file
- and when i get the file into the list what should i make the amount of seconds be for the track..?
I am also having trouble with creating the menu in Nero5.5 i created the menu but when i burnt it it wasnt there..?
I also read the tutorial on this site but it was unable to help me,
I have VCDEasy but i find Nero easyer to use,
And what is a good Freeware program that can play VCDs and most other video files?
Cameron,
HELPPP MEEE>>>>
I have the same problems as you. Hope someone answers. I also sign in at Nero forums, but I can't access anything. It says I must sign in first, lol
Then Nero won't let you make a SVCD unless you buy a plug in. That's BS! -
The files you have were, I'm guessing here downloaded from the internet.
Many of these are not encoded to VCD and SVCD specs. To get these to burn to disc so you can use them in a standalone player, you will need to re-encode them to make them compliant. I suggest using TMPGEnc to re-encode them. Look in the Tools section on the left side of the page to get TMPGEnc and in the Guides section for info on how to do the re-encoding. -
Yeah thanks i did download them from the net!,, so if anyone has anything else to say.. help!!
HELPPP MEEE>>>> -
If the file is already MPEG1, then run it through either M1-Edit->Tools-> repacketise or TMPGenc->MPEG Tools to correct errors.
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 22nd Aug 2010, 00:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 16:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 19:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 19:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 15:00
