System:
Iwill KA266-R; AMD 1.2g; 256mb DDR ram; WD 120G 8mb cache (C: 40mb /D: 80mb); std CD-R; PlexWriter CD-RW12/10/32; Sony DRU500A; WinXP w/SP1; all IDE based;
Issues:
DMA...ON or OFF (and for which drives)
ASPICHK says NO ASPI layer installed; which version to use?
Anything else I need to ensure about hardware?
Software:
Will be installing the following;
nero 6 ultra; alcohol 120; CloneCD; ClonyXXL; DVD2ONE; dvdshrink; recordnowmax; dvdidentifier; and other tools /utils that this site (or others0) may recommend.
Any comments/suggestions regarding software?
Thanks much...
i dunno why you need all that software..
nero for basic cd burning
recordnow max for dvd burning
alcohol 120% for those difficult to copy cd's..
dvd decypter for dvd ripping
cdrwin to make nice pretty cue/bin's of cd's.
(not gonna mention dvd encoding/transcoding utils)
look around for forceaspi. i use it to install the aspi layer on all xp systems i work with..
and you really do need more ram, its cheap enough, i'd get two 512mb sticks. -
Your cd and dvd burner should be DMA enabled. You may download the ASPI from this site:
http://www.adaptec.com/worldwide/support/drivers_by_product.html?sess=no&language=Engl...dkey=ASPI-4.70
Good Luck!
Thank you everyone....I appreciate the replies.
Ok...I'll enable DMA for CD, CD-RW & DRU; I've got ASPI layers...thanks for advising which version.....and for programs...they were selected after reading user comments....but I am open to suggestions...for example...I have DVDXCOPY...but the general comment is lower video quality.
I've got CDClone, Alcohol 120 and Nero....all of which have received good feedback....and as I'm a "noobie" to this....I guess I'm after programs that can produce good video and audio quality DVD's & CD's. Yes, I will be reading the tutorials for the programs I end up using.
So whatever the voices of experience offers advice wise, it is appreciate and will be reviewed.
On the memory thing...I'll have to get this one by "she who must be obeyed"; not to fond of all this computer thingey stuff....what can I say.....
Thanks again for the input....it's greatly appreciated...and keep the advice comming.
Regards....
Minimum System requirements for Bluray ripping/burning?
By orbital517 in forum Blu-ray RippingReplies: 12Last Post: 28th Oct 2010, 12:32 -
Multi-System VCR (Panasonic NV-SD230) - Some quick questions
By quantass in forum Newbie / General discussionsReplies: 0Last Post: 18th Dec 2008, 00:47 -
I'm New to Burning DVDs: I have quite a few questions
By emoney3265 in forum Authoring (DVD)Replies: 15Last Post: 13th Aug 2008, 17:00 -
Questions About a New System I Built
By Soopafresh in forum ComputerReplies: 9Last Post: 11th Apr 2008, 06:04 -
new to dvd burning - questions!
By tiredbunny in forum Newbie / General discussionsReplies: 3Last Post: 8th Sep 2007, 12:00
