Instead of ripping everything from a DVD, is there a way to just rip the audio??
i.e. I don't want to waste too much spaces storing the video.
Re-encoding into VCD format is also undesirable,
because I want the audio to stay at its original quality.
What tool would you recommend??
I would use DVD2AVI...
You might be required to create a small .d2v file, but within the AUDIO section, you have a chance to rip all the streams that exist.....
Apparantly, DVDDecrypter will rip the .AC3, but i'm not familiar with that method...I assume that you could rip the elementary streams, but leave the video option unchecked....
Good luck!!! -
Try this link, for what you are looking for :
http://www.dvdtox.com/dvdaudioripper.htm
Also, to do it for free, which does involve ripping the DVD. I assume you want to avoid this, due to space, rip as normal using DVDDecrypter, then use AC3Tool
It can be done with DVDDecrypter, without ripping the enitire DVD, but I've only done it once or twice, you need to rip just the audio stream, I think its under 'Stream Processing'. The docs with DVDDecrypter are not the most user friendly, but have a look on here in the guides, somebody may have done it already
Then use AC3Tool to convert the AC3 to either MP3 or WAV, with the option of downmixing the 5.1 audio to 2-channel stereo, if required
Rip audio from DVD chapter
By TYLER08027 in forum DVD RippingReplies: 3Last Post: 11th Jul 2010, 14:16 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 13:40 -
My DVD rip w/ no audio
By towarmforacoat in forum DVD RippingReplies: 1Last Post: 28th May 2009, 11:03 -
Audio Rip from DVD
By MI6 in forum AudioReplies: 1Last Post: 8th May 2008, 04:32 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 27th Mar 2008, 23:33
