One of my partions is 61.5 gb and I select all the files on it and it is 7.79gb but when I check how much space is taken up on the partition, it is 16.5. It is not my primary partition either. All the other drives are show correct amount of space but not this one. Does anyone know what takes up the space.
probably recylcle bin files.. or do you have norton system works installed? That likes to hide hard drive space.
I got nothing in recycle bin and no system works, only the nav antivirus.
You probably have XP's SYSTEM RESTORE turned on for that drive and files used to be able to "roll-back" your system are taking up that space.
Ripper2860, I think you right, I just checked and system restore is on for that drive and it matches the amout of space. Do I need system restore for that drive if I got no system files on it. I just keep my AVIs, mp3s and stuff like that on it.
No -- just if you install programs to that drive. If it is just Data -- no need to have it enabled for that drive.
Result doesn't match my AVCHD quality
By davidplante in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 22nd Mar 2012, 09:37 -
Virtualdub keyframe picture doesn't match the actual video
By yuvid in forum EditingReplies: 1Last Post: 1st Feb 2012, 01:57 -
Vob2Mpg Pro, Time doesn't match!!!
By DATENSCHUTZ1 in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 21st Apr 2010, 04:05 -
Video Type Doesn't Match prob when compiling DVD Lab Pro project
By ulrichburke in forum Authoring (DVD)Replies: 6Last Post: 11th Dec 2007, 13:31 -
Is VCD/DVD disc space limited by time, or space?
By pingosimon in forum MacReplies: 6Last Post: 14th Jul 2007, 19:55
