Another newbie question. How do i resize the thubnails in Tmpgenc dvd author to the correct resolution? It seems when I try to create a custom menu the chapter thumbnail appear distorted or stretched. Suggestions please.
Don't think you can directly change thumbnail aspect ratios in TDA's edit menu.... while you can change/move the thumbnail rectangle itself.
so, if you select an image from the video being authored, whatever aspect it is will be shown in the thumbnail.
Howver, if you choose an image file (jpg, bmp, etc.) a workaround would be to resize the image's aspect ratio to 4:3 using a photo editor priot to importing it into TDA .. and then matching the thumbnail rectangle to the thumbnail image. -
Hmm okay. I heard that suggestion before but how do I resize the thumbnail picture using the ratio you just mentioned? What program should I use?
multiAVCHD menu background and chapter thumbnail creation
By Delta007bhd in forum Authoring (Blu-ray)Replies: 12Last Post: 7th Dec 2016, 09:19 -
Change menu thumbnail in multiavchd?
By mikeveli20 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Oct 2011, 18:27 -
TMPGenc 4 Menu Thumbnail Issues
By Twash5 in forum Authoring (DVD)Replies: 0Last Post: 18th Jul 2011, 13:43 -
Animated thumbnail (playing thumbnail) in DVD menu??
By blizzery in forum Authoring (DVD)Replies: 13Last Post: 9th Nov 2007, 02:46 -
TMPGEnc DVD Author 1.6 thumbnail menu issue
By Bix in forum Authoring (DVD)Replies: 0Last Post: 3rd Oct 2007, 11:00
