Hi, just recently figured out how to use the tmpgenc dvd author, (the whole reason was to create a menu) and after using the program I went to use nero to burn it to a dvd-r. (Drag n drop all the files to the TS_video folder) After burining the files I popped it into my dvd player and for some reason the menu screen doesnt display. It just plays the videos without displaying the menu but when I clicked the menu button it shows up. Can someone tell me how to fix this? I want to have the dvd menu display the first thing when I load it in the dvd player. Thanks!
you may have to tell it what to do with menues... there is a menu options button "DISPLAY MENU SETINGS" (under Create Menu) where you can tell it to display the main menu first or other options.
If you want to save time loading another program and dragging and dropping files; TMPGEnc DVD Author has a excellent burning app.
TMPGenc 4 Menu Thumbnail Issues
By Twash5 in forum Authoring (DVD)Replies: 0Last Post: 18th Jul 2011, 12:43 -
TMPGEnc Authoring Works 4 - Menu help
By NotSoEasy in forum Authoring (DVD)Replies: 9Last Post: 1st Mar 2010, 02:24 -
TMPGEnc AW 4: just 1 menu for chapters in different tracks
By reini in forum Authoring (DVD)Replies: 4Last Post: 25th Mar 2009, 05:17 -
TMPGEnc 3 - Quick Menu Question
By heyjjjaded in forum Authoring (DVD)Replies: 1Last Post: 17th Aug 2008, 14:05 -
TmpgEnc Menu Confusion
By marioval in forum Authoring (DVD)Replies: 6Last Post: 12th Oct 2007, 06:23
