Hi,
I've tried to convert various divx and xvid encoded films using tmpgenc plus and not one of the files are encoding! I have used BeSweet and I have more than enough codecs.
I've changed the environmental setting to a higher priority and its still not working.
Im trying to convert either xvid or divx to dvd compliant mpeg-2 but this has set me back please help!
Craig
Results 1 to 10 of 10
So what happens when you try to convert. Error, file too big, out of sync ????
What do you mean playing blank when encoding with Tmpgenc ? You mean you don't see the output video in tmpgenc ? or it produces a blank file ?Originally Posted by cadunbar
I take it you actually have an MPEG2 codec installed ?Originally Posted by cadunbar
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Yeah I do have MPEG-2 codec installed when encoding the output screen is blank and the file just encodes blank.
Craig
Can you load the original divx in VirtualDub, and if so will it do a Direct Stream Copy?
Tried that mate but it wouldnt work it came up a message saying no audio decompressor could be found i think.
Craig
Ok, then I would say the divx file has AC3 audio and you don't have AC-3 ACM Decompressor installed. VD needs that to be able to work with AC3 audio. Do you have it installed?
Also another great program I use is AVICodec. It is just a simple tool that tells most information about a video or audio file. I use that software all the time checking my video files out, but VD is also a very useful video tool I use almost daily.
Divx files with problems I have found it very helpful to simply do a "Direct Stream Copy" (audio & video) in VirtualDub. This simple routine will not reencode the file but it can repair many errors. Once copied I would then attempt another conversion with TMPGEnc. It should then work normally.
Did you watch the SuperBowl? Great game. -
Hi thats great advice
thanks ill try installing the codec and try a direct stream copy
I never watched the superbowl mate as Im from Scotland and it was on at like 5 in the morning
Ill let you know how i get on!
Craig
Certain audio tracks not working during/after conversion
By yFSC in forum Video ConversionReplies: 1Last Post: 6th Dec 2010, 17:53 -
My MKV file already has AAC audio so the conversion tools arent working
By animlchin in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 17:58 -
VOB2MPG Pro preview not working & conversion slow
By MDJH in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 22nd Sep 2009, 14:01 -
ffmpegX conversion in x264 not working
By trovon in forum ffmpegX general discussionReplies: 1Last Post: 18th Apr 2008, 13:05 -
AVI conversion to H264 for iPod not quite working
By rumplestiltskin in forum MacReplies: 11Last Post: 1st Dec 2007, 00:48
