I have a avi divx5 pro file with ac3 5 channel and when i use TMPgen to convert to dvd it gives no sound .
when i use mpeg main concept program it reduces the 5 chanel to stereo
what program can I use to get full 5 chanel , or what add on for tMPgen
https://www.videohelp.com/guides.php?link=447
Note that you don't have to encode the video again if you already have done that, just follow the first step in that guide and you will get an ac3 file. Then use tmpgenc dvd author and import your mpg and choose the ac3 sounds insted of the stereo sound.
and please don't post conversion questions in the authoring forum. I'm moving your topic.
mkv with ac3 audio -> avi with ac3 audio ? is this possible?
By Substance001 in forum Video ConversionReplies: 9Last Post: 21st Jun 2011, 00:56 -
additional audio decoder needed to play this soundtrack-Dolby AC3 Audio
By tbone1209 in forum AudioReplies: 6Last Post: 19th Jun 2011, 21:58 -
Avi to Ac3 user guide. How to encode the audio from an avi to ac3 .
By freebird73717 in forum User guidesReplies: 5Last Post: 9th Dec 2009, 22:53 -
FAVC re-encodes AC3 audio even when I check the "retain AC3" opti
By teapot in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2008, 01:10 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19
