THe VCD seemed a little blocky when played back on the TV. Could this be a result of using 4:3 NTSC on the Advanced tab in settings on TMPGENC? Is that setting somehow stretching the picture and causing the blockiness? Will VCDs play if the mpeg was made with 1:1 VGA setting in TMPGENC?
Is there a filter that can reduce blockiness or other lines that appear in video in VirtualDub?
Results 1 to 10 of 10
Does 4:3 setting cause blockiness? Hmmm ... maybe you should encode a short clip where blockiness occurred and post your results using 4:3 and then VGA 1:1. It just might make a difference. And I would also like to know.
Some settings make no difference. For instance, Soften Block noise is completely useless for fast motion blocks. You'd be better off using Motion Blur in Virtual Dub combined with Blend Deinterlacing in Tmpgenc. However the result is kinda dark and blurry. So you gotta increase the brightness in VD too.
Someone also mentioned changing GOP IBP values to 1,1,1. I haven't tried this yet as my hard drive is currently filled.
The blockiness is a compression artifact that you will have to live with if you want to make VCD's. Only if the source is really good, and you use non-real time compression, can you reduce the blockiness, but not remove them all together. During fast action and high motion, you will see blocks in the video. This is Mpeg compression at work.
VCD is only 1150/sec
where DVD can go up to 10,000/sec
plus..VCD is 352x240
DVD is 720x480
That's why DVD is so much better..
More then double the res....
More then quadruple the bitrate!!
Jason
Original BREW-Crew #3 -
OK, in order to tell you how to make a better encode we need some more info: source (DVD rip, DivX, video capture, etc) and the settings you used to encode.
You should check the DVD Players list to the left to see if your player will play xVCDs. If you might want to consider uping the resolution to 352x480 or 480x480, set motion search to high, use 2pass VBR, detect scene change off, up bitrate to either full CDR or to DVD players max.
This assumes good source. A DivX source will is normally not going to make a good x(S)VCD no matter what you do to it. You can't 'improve' the quality. But a DVD rip... you can make an encode of nearly DVD quaility (using 2 80min CDRs for the ave movie). -
Your VCD's are blocky? Perhaps you should read this topic first.
thats some funny shit... gotta go, hockey is on!!!
later bater. deltaboy
Cant get rid of aliasing
By killerteengohan in forum RestorationReplies: 7Last Post: 7th Feb 2012, 23:33 -
How best to convert/get rid off VCD/DVD/HDVD9?
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2010, 00:17 -
how to suppress vocal on karaoke vcd made from video files dowloaded
By sabaideevh in forum Video ConversionReplies: 6Last Post: 3rd Aug 2009, 05:57 -
Getting Rid of Subtitles
By macbuz in forum MacReplies: 4Last Post: 16th Jan 2009, 19:09 -
getting rid of vista
By sue1951 in forum ComputerReplies: 12Last Post: 6th Aug 2007, 21:53
