I have stripped the sound from a avi file. The sound contains spanish commentary but it is done on top of english commentary and natural sound.
I wish to remove the spanish commentary so I am left with the english commentary, or invert?? the sounds so that the english and natural sound is louder than the spanish language?
Can you anybody point me in the right direction of what to do and what audio editing software is best?
Cross your fingers and hope one language is one channel, and the other on the remaining channel.
Load the original video file into Gold Wave. If it shows two channel stereo select Edit-->Select channel-->left.
Select--Tools-->Device controls. A little sound player will appear. Press the Play button. If one language is heard, you're in luck so far. Press Stop.
Select Edit-->Select Channel-->Right. Press play on the player again. If the other language is heard, you've hit the jackpot. Select the channel with the language you do not want, and press the Delete key. This drives the selected channel's volume to zero.
Select the remaining channel, and Edit-->Copy. Select the "empty channel" and select Edit-->Mix. This copies the audio from your remaining channel to the "empty channel". Save as a wave file. Voilą!Hello. -
No the sound is mono. Looks like plan B then, learn spanish!
Thanks for the info anyway, may prove helpful in the future
Removing formatting from srt files?
By branch in forum SubtitleReplies: 30Last Post: 15th Jan 2021, 10:20 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 08:26 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
removing letterboxing on MPEG2 files
By hellsaviour in forum MacReplies: 3Last Post: 13th May 2007, 14:17
