hi guys
just finished ripping some clips from various dvds and im authoring them with TMPGEnc DVD Author with AC3 plugin, and when i have come to author (output) i get this error for like 8 of the clips ive ripped from vatious dvds:
i ripped the clips using dvd shrink (reauthor mode)*The combined bitrate of the clip exceeds the upper limit for a standard DVD.
The combined bitrate of the video and audio of clip "xxxx" of track "xxxx" is exceeding the upper limit for a standard DVD.
The current bitrate is xxx kbps for video, xxx kbps for audio, and xxx kbps combined.
It is necessary with a combined bitrate of less than 9.848Mbps (9848kbps).
then used Rejig to demux the video and audio and added them to dvd author.
anyone know how i can get rid of this error, what do i need to do exactly?
any help appreciated, thanks
I don't think you will have a problem with this DVD
It could be that the header information is wrong but that the actual bitrates used are ok.
This can happen with CINEMA CRAFT ENCODER when you set it to MAKE COMPLIANT DVD it will set the header to the MAX bitrate even though you might be using a lower bitrate.
TMPGEnc DVD Author only reads the header and gives you that "error" message.
So my guess here is that the same thing is happening and the bitrates used are A-OK but the header info is "messing" up TMPGEnc DVD Author. Just ignore the "error" emssage and continue.
I doubt you will have any problems or issues.
I just did a DVD with this exact error message. DVD turned out just fine.
Thanks for the confirmation.
Bitrate Limit for BD9?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 6th Jan 2012, 08:56 -
TMPGEnc "clip total bitrate too high for a DVD-Video" issue
By dread in forum Authoring (DVD)Replies: 7Last Post: 26th Oct 2010, 16:34 -
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
Authored DVD exceeds DVD spec bitrate - advice needed.
By outerspacerace in forum Authoring (DVD)Replies: 27Last Post: 14th Jun 2008, 23:23 -
AC-3 bitrate limit on Apple TV?
By InsanelyOne in forum MacReplies: 0Last Post: 8th May 2008, 11:18
