Hey,
Been trying to convert a downloaded AVI to dvd mpeg2. I ran it through VDUB first to delete bad frames....then extracted the audio to WAV. Once i convert it with tmpegenc the audio goes out of sync about halfway through...i first noticed it at the point i deleted the bad frames. Any suggestions would be greatly appreciated!!!
Mike![]()
Results 1 to 11 of 11
It's DiVx with mp3 audio. Anywhere I can look up MainConcept...any users guide?? Is it freeware??
www.mainconcept.com
It's trialware, not freeware but will at least see if it helps.
Tom -
Tried MainConcept...same sync problem....could i have a bad codec installed?!?!? This is driving me nuts!!!! What's the best method of converting Divx to DVD...hands down?
I tried MainConcept with the Xvid videos that I had and it worked flawlessly. It even appears to be faster than CCE. I got my Xvid codecs from Doom9.
I'm using Main concept 1.4.1 i'm trying to encode to DVD. here is the file information when loaded into main concept
Video input info
Frame Rate 23.976
frames 123094 Lenth 1h 25m 34s
Size 544x288 pixel
audio input info
sample rate 48000
Sample 24643231 lenth 1h 25s 34s
bit per sample 16
When I load that AVI file in Main concept output format automaticly switch the output format to
MPEG TYPE-mpeg 1 Video mode NTSC
Sample type-video+audio audio mode layer 2
mpeg 1 544x288 pixel 29.97FPS 48000HZ 2 channel 16 bit
Now i switch the MPEG TYPE to DVd nothing change but pixel and audio to lpcm now i hit encode when the output file finish and i play it the file is out of sync audio dont match video but in the begaining it does match about half way though the movie it off
how can i fix this please help my step by step please -
MtBuckley46,
Try frameserving the videostream to TMPGEnc with VirtualDub -
Hey everyone.... I solved my sync problem. I had suspected that it may have been a codec issue. I had K-lite codec pack installed. I uninstalled it and installed Nimo Codec pack......bye bye sync problems.
where did you get this nemo codec pack from - does it have all the codec included - I too am having problems with audio sync problems and it is driving me nuts!!
AVI to DVD: help with audio sync problems
By tanglemac76 in forum MacReplies: 9Last Post: 23rd Dec 2010, 15:50 -
A/V sync problems with an AVI...
By takearushfan in forum Video ConversionReplies: 0Last Post: 17th Aug 2010, 18:41 -
sync problems with flv to avi
By cynikalhedonist in forum Video ConversionReplies: 5Last Post: 15th Jul 2010, 08:34 -
WinDV sync problems (Update: never mind, it's a TMPEGEnc problem)
By timmus in forum Capturing and VCRReplies: 0Last Post: 6th May 2009, 15:39 -
Xvid AVI DVD Playback Audio Sync Problems
By lozza_c in forum Newbie / General discussionsReplies: 5Last Post: 8th Jun 2008, 09:38
