  1. With every film that I have extracted from a .bin file using ISOBuster (eXtract .mpg), I get the following error when I try to multiplex a subtitle using WinSubMux 0.2.0.2:
    Multiplexing...
    *** Incorrect packet[0xBA010000] header at 0x00000004 ***
    * Unknown header 01 bb 00 0c *
    * Skipped 2310 bytes of garbage *
    This is really anoying since quite a few films are found already in VCD or SVCD formats on the net.
    Anyone with the same problem ? Your help is appreciated.
    Sil
    By the way, I have tryed demultiplexing and remultiplexing the .mpg files using TMPGEnc and I get the same problem. I have also use MPEG corrector to check for bad headers without any luck.
  2. And the problem is not with the .sub file and .bmps ... I have done this quite a few times already :)
    Sil
  3. By the way, I forgot to mention that as soon as I click the multiplex button, the error appears consinuously for different packets. I can't even stop WinSubMux (so I have to kill the process).
    Any other software doing the same thing as WinSubMux ?
    Sil
