Results 1 to 12 of 12
    Apr 2002
    Fremont
    Hi
    I have a question:
    I used Dvdshrink to compress something and now I have a VIDEO_TS folder ready to be burnt.
    Problem? Stupid me screwed up and it's a couple of hundred megs oversize and somehow Nero isn't cooperating in overburning.
    So, how could I reduce the size of the VIDEO_TS folder to get it to fit?
    Thank you.
  2. just re-encode it again.
    or do the original files,but at a slightly smaller size.
    Apr 2002
    Fremont
    That's the problem...I don't have the original files anymore.
  4. Just run the files through DVD Shrink again that usually does it.
  5. Human j1d10t's Avatar
    Feb 2003
    California, USA
    I'm not going to ask why....
    But you can still shrink it with DVDShrink - just use the Open File button, instead of the Open Disk button......
    "Don't try to be a great man. Just be a man, and let history make its own judgment."
    Zefram Cochrane
    2073
  6. I'm not going to ask why....
    me either
    Apr 2002
    Fremont
    me either
    The whole reason of backing up the DVD was because it was getting scratched. I had to save it, ya know.
  8. Excuse sounds a little lame to me.
    Apr 2002
    Fremont
    I am not making an excuse and neither am I asking you to believe it. I am asking a question: how do you shrink the video_ts folder so it fits on a standard dvd-r.
    Thanks for the help.
    Apr 2002
    Fremont
    Thank you sir, this really helped.
  11. Originally Posted by Serpent
    I believe ya
  12. Human j1d10t's Avatar
    Feb 2003
    California, USA
    Glad it worked out for you
    Zefram Cochrane
    2073
