Is there a way or a program that will convert my 2.35.1 DVDs to an aspect ratio of 1.78.1 and then burn it back into a DVD+R? Unfornately, the anamorphic DVD isn't fully fill my widescreen HDTV despite so much rave about it.
Any suggestion is greatly appreciated.
ljCharlie
You could use TMPGEnc to do that......of course you're going to lose horizontal resolution by doing so.
"Hello. My name is Inigo Montoya. You killed my father. Prepare to die." -
hi ljcharlie,
ok, now I have a better understanding of your reason to change from a
2.35 to a 1.78, but really, you are actually distorting the AR. That 2.35 is
the actual Aspect Ratio for a 16:9, and you need the black bars there, for
it to be correct. I know you want to fill your ws tv set, but there are several
different flavors of ws presentations. The old (slightly original) way was
the 16:9 (or, 1:77777778.1) or 1.78 which filled a standard ws tv set. Then,
they decided to add other AR variations, but still maintaining the AR for the
16:9 view. The only downside to this is that on some them, you'll notice
a few small boarders. Example, the 1.85 will give you some small boarders
but barely noticable. But, the 2.35 is a much more smaller video area,
giving you more boarders to your screen. But, this is still normal, and still
in the same correct AR for your 16:9 because it's using the 16:9 matrix.
If you go and stretch it, you'll be effectively stretching the people (taller)
on your set.
-vhelp -
I agree with vhelp
A 16x9 WS TV has an aspect ratio of 1.78:1
So to watch a movie with an aspect ratio of 2.35:1 you have to have some black above/below the image to preserve the aspect ratio.
The only option to fill the screen is to stretch the image to fit which will cause distortion (people looking too tall and thin) or to cut some off of the sides so that you are enlarging the image to fit from top to bottom and of course that is NOT a good idea and goes against the concept of WIDESCREEN which is to KEEP the aspect ratio and the entire image.
It might help to read the following link:
http://www.widescreen.org/
This website describes the concepts of WIDESCREEN including different film/video formats and perhaps most importantly gives many examples of FULL SCREEN presentations over FULL FRAME WIDESCREEN presentations.
GIVEN UP,Now how to convert Mpeg 2 to a clean AVI with same aspect ratio ??
By mudh in forum Video ConversionReplies: 4Last Post: 11th Oct 2011, 16:04 -
How to convert squashed DVD aspect ratio back to normal??
By EricBalir in forum Video ConversionReplies: 5Last Post: 9th Sep 2011, 22:36 -
change aspect ratio & convert m2ts files & brighten videos
By rockerman in forum Newbie / General discussionsReplies: 3Last Post: 21st Jul 2011, 07:34 -
Trying to convert .mov to .flv - aspect ratio problems
By Graeck in forum ffmpegX general discussionReplies: 12Last Post: 21st Oct 2010, 17:55 -
Easiest, fastest way to convert MKV to Blu Ray with 1080p aspect ratio
By jfk8680 in forum Authoring (Blu-ray)Replies: 3Last Post: 12th Apr 2010, 23:07
