I am planning to create a video of a kind of famility tree timeline. At the bottom of the screen I intend to show ongoing horizontal scale type lines indicating dates / years (similar to an old fashion ruler).
In the upper portion I intend to put pictures and film. I dont see a problem creating this in Vegas with the opacity envelopes but I dont know how to create the bottom portion / let me call it the ruler effect.
Can anybody give me some advise on this ?
Try Adobe After Effects, and create a composition. You can download a thirty day trial frome Adobe, the help file will guide you through the basics of creating composites and animation.
Just shut up and listen dumbass -
you can do this easy enough in Vegas - follow this guide http://www.martyhedler.com/homepage/Veg_Maps.html
click on the "maps and Lines' tutorial at the top"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks for the replies however, Adobe After Effect has a list price of $699.00 for Std Full and 999.00 for Pro Full (not in my budget) and 'Maps & Lines' from "Martyhedler.com" are very good but not really useful for creating my ruler effect with short vertical lines with dates on them at the bottom of the screen running thruout my video.
I appreciate any other advise. Thanks.
40 second animation
By Ken-B in forum Off topicReplies: 3Last Post: 24th Nov 2011, 09:23 -
3D modeling and animation?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2008, 09:58 -
animation to dvd
By J. Baker in forum Authoring (DVD)Replies: 3Last Post: 31st Aug 2007, 02:53 -
Cartoon Animation
By dbanga in forum Newbie / General discussionsReplies: 6Last Post: 19th Jun 2007, 12:46 -
vegas 5 animation
By gomez1 in forum Newbie / General discussionsReplies: 12Last Post: 15th May 2007, 22:27
