  1. OK, ive tryed to joing two mpg(vcd files) together .Ive tryed DV Tools and Rejump movie joiner, they do the job, but at the point where the files are joined the picture freeze's for about 5 seconds.If i join em with tmpgenc theres a squeak at the join, and after the join the audio seems to be about a slipt second out.Or theres just a squeak.
    How do i join two mpg files together so they flow smooth.???
    Also the two files come too 1.38GB, but once tmpgenc joins them the new file is 1.21GB and the time length is shorter.
    Big 3 User.....
    PAL User.......
  2. I too am having the same problem... Joining 2 Mpeg1 files... Have you or anyone found a good fix, or is it easier to just re rip the movie....
    LOL
    Eminencedjs
