Results 1 to 9 of 9
  1. I apologize if my question doesn’t fit the criteria of this board. Anyways, does anyone know a good place to buy (hopefully inexpensive) DVD cases? How about dual DVD cases (which are the same dimensions of a standard DVD case)? Many thanks!
  2. Well if you in the Uk SVP do them as do most suppliers of dvd disks. Just got some double disk cases from SVP 13p each. Last lot of singles i got were £10 for 100 from a comp fair...
    Not bothered by small problems...
    Spend a night alone with a mosquito
  3. Member NamDekan's Avatar
    Jan 2004
    Indiana
    i got some of the double DVD cases on ebay, i won an auction for 10 for 1 cent but the shipping was steep, but they got better deals on there though.
  4. Well, are there any reliable sites that sell them for less than a buck each (price isn't too much of an issue). I just need them to have the same height/width/depth of a standard DVD case.
  5. Fry's Electronics has single and dual Meritline cases, $3.99 for a 10pk. The duals are the same size as the singles. But that would only work if you live near a Fry's.
    Nov 2003
    Houston, TX
    or rima.com has them for 24 cents each (single)
    josh
  7. http://www.rima.com is the best source I have been able to find. You have to buy a lot thou (packs of 100). IIRC I got 100 double cases for ~$30 including S&H.
    May 2003
    50 for 5 bucks at computer shows try www.marketpro.com or www.tri-statefairs.com
  9. WWW.SUPERMEDIASTORE.COM
    100 pack of single's $23 ( via coupon "case5off" )
    also...
    100 pack of double's $28 (with free shipping)
    I just got this flyer (expires 2-8-04) from them with my order of 25 Ritek RiData G04's
