I have a new dvd writer., so i tried 2 make backups of my DVD. But because the newer dvds are dual dvd and have a capacity of 7+ GB how can i burn it on a 4.7GB DVD? Is there any DVD burners dat can use 7+ GB DVD's discs? The only way i think is 2 remove chapters and stuff, and compress it.
But is there any way 2 make an exact copy of the DVD with chapters, special features, etc?
The only thing i saw was DVD ram dat uses both sides which it 9.2GB.
Sam 8)
'All Beings Are Created Equally and so Must Be Treated'
'The Universe Is A Clock, Everything Depending And Workin Of Eachother' -
you either have to split onto 2 dvds or shrink. off course if you did any research on this matter you would all ready know this....
How Big A Boy Are Ya? -
dual layer writers are in the works. you'll just have to hold off, unless you want to split the disk and put part on one side and the rest on the other of a double sided disc. you can get +/- double sided discs, not just RAM that way. They aren't very common though.
Sorry i remember it asked for 2 discs 2 copy the dvd. Glad 2 hear dual discs are in the works.
Thanks 4 clearin dat up.
Sam 8)'All Beings Are Created Equally and so Must Be Treated'
software to edit iphone videos on a 1.6ghz cpu, 2gb of ram, 30gb free space
By v1p0n3 in forum EditingReplies: 0Last Post: 17th Feb 2012, 06:47 -
how do i copy DVD RAM discs to pc hard drive (retaining exact file quality)
By mnbvc in forum Authoring (DVD)Replies: 3Last Post: 19th Apr 2008, 17:32 -
Copy recorded DVD-RAM to DVD-RW?
By Trollheart in forum MediaReplies: 11Last Post: 15th Apr 2008, 14:32 -
LGA 775 Mobos That Register Above 2GB RAM
By Soopafresh in forum ComputerReplies: 5Last Post: 7th Sep 2007, 20:41 -
Is there way to copy a Dvd realtime with RAM drive like a standalone playr?
By Blumphf in forum DVD RippingReplies: 18Last Post: 25th May 2007, 06:21
