Hello,
I am using scenarist from dvd2svcd to convert an avi to dvd I set to fixed chapters at 900sec/chapter. Everything works ok and it creates the dvd image, but it puts the second chapter at the end of the movie for some reason. So when your playing the movie and it gets to the end of chapter 1 it jumps to chapter 3. Anyone know what could be causing this? I can manually go into scenarist and rearrange the chapter order and this seems to fix the playback but if you hit the forward button it jumps from 1 to 3 still.
thanks
vifa
Just to follow up: I tried changing the chapter cut length to 600 seconds and it did the same thing, put the second chapter at the end. I just wonder if this is from svcd2dvd writing the script or if it's a problem with scenarist? Somehow the navigation is getting screwed up. I haven't tried a different avi yet, I guess that's next. I figured out how to rearrange chapters in scenarist, and this fixed the playback part. i.e. if your in the first chapter and it plays to the end of the chapter it doesn't skip and jump to the third. However, it still skips the 2nd chapter if you press next while in the first chapter.
Anyone know how to set navigation of chapters in scenarist. I.e. which chapter it jumps to when you press next or previous on the player?
appreciate any help.
vifa
out off order chapters
By vadded in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2009, 13:11 -
Chapters out of order
By briandugas in forum DVD RippingReplies: 4Last Post: 27th Oct 2009, 13:57 -
Changing the order of chapters in idvd
By caspera in forum MacReplies: 3Last Post: 16th Sep 2009, 02:34 -
DVD Plays Chapters Out of Order
By spntr in forum DVD RippingReplies: 3Last Post: 15th Dec 2007, 11:18 -
How would I change the order in which chapters are played, please?
By c627627 in forum Authoring (DVD)Replies: 123Last Post: 5th Sep 2007, 03:48
