I use Terratec cinergy 600 tv tuner (Phillips SSA-chipset). I can capture whatever resolution I like but I am not completely satisfied with the software - its too unstable, cut off captures and so on. Therefore I prefere VirtualDub wich is good, stable and simple. But I can only capture in 352 x 288 (vcd) with this software. When I try to change resolution, data format, codecs ect. it wonīt capture a single frame. The program tells me to lower the colourdepth, which doesnīt help, or that the hardware might not support this resolution, which it does when I capture with Terratec software. I have learned that VirtualDub donīt work that well with WDM-driver based hardware like cinergy 600, but can that be the only problem?? I use VirutalDub 1.5.10 MPEG2 and use the latest wdm-drivers from Terratec. Does anyone have a clue??
Virtualdub - No Preview during Capture
By FatBoy123 in forum Capturing and VCRReplies: 5Last Post: 6th Jun 2010, 05:14 -
Virtualdub settings to capture DV
By magillagorilla in forum Capturing and VCRReplies: 12Last Post: 11th May 2010, 14:42 -
VirtualDub for capture app?
By pgoelz in forum Capturing and VCRReplies: 17Last Post: 4th May 2010, 15:44 -
VHS Capture with VirtualDub-Several Problems
By Daniel90 in forum Capturing and VCRReplies: 19Last Post: 13th Oct 2007, 20:00 -
Timestamping VirtualDub capture
By AIVAS in forum Newbie / General discussionsReplies: 1Last Post: 19th May 2007, 12:44
