Hi,
I have TMPGEnc Plus and i was trying to convert from VCD to SVCD. I used VCDEasy to extract it to my hard drive and then i tried to load it in the Video box in TMPGEnc and this is the error i got. File "C:\Documents and Settings\Derek\Desktop\AVSEQ01.mpg" can not open, or unsupported. So i got instructions on how to repair it from https://www.videohelp.com/tmpgenc/
I used ISObuster to extract it separate from my desktop and use VCDGear. There are my settings for VCDGear and the error i got trying to repair it.
Undet the vcdgear tab: raw [ track image] -> dat
Fix MPEG errors checked
Load the extracted mpg file that ISObuster made and save a new name.
Here is the error i got with VCDgear trying to repair it: Could not locate MPEG stream.
Why couldn't i load the VCD in TMPGEnc Plus and why couldn't i repair it using VCDgear?? Thanx for any help.
It may be there is nothing wrong with your file. Click here.
Hello. -
Originally Posted by dsantamassino"Art is making something out of nothing and selling it." - Frank Zappa
I already looked at that site. That where i got the instructions on how to repair it.
And yes it only plays SVCD's. Do you know what should i do now or know how to fix the unsupported file?? Thanks. -
Did you raise Directshow priority?
"Art is making something out of nothing and selling it." - Frank Zappa -
yes. It was orignally set for -1 and i just raised it to -10. I still get can not open and unsupported.
I had it at -10 and then now i put at (10) which is + and still unsupported.
TMPGEnc Xpress 4.0 stuttering conversion errors
By CasanovaFly in forum Video ConversionReplies: 2Last Post: 26th Nov 2009, 15:32 -
Why so many errors with imgburn?
By happydog500 in forum Authoring (DVD)Replies: 20Last Post: 29th Aug 2009, 10:08 -
svcd preview errors & vob file errors
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 16:02 -
How to scan for any errors?
By Kwan in forum Newbie / General discussionsReplies: 6Last Post: 1st Oct 2007, 06:59 -
check a DVD for errors/read errors?
By ebob in forum Authoring (DVD)Replies: 4Last Post: 5th Jun 2007, 10:53
