Are there any programs that will create a virtual device like the one Nero has, that can be used by other programs? 'Cause I have something I want to do so with with Fireburner, and I'm out of -actual- CDs at the moment.
Thanks for any help.
Pips
clonecd has a virtual drive that does theri images and iso images and daemon tools i believe will do a lot of different images
I also recommend Daemon Tools.
Alcohol 52% (mounting images, no burning, for burning you want Alcohol 120%) is good also, there's a free trial @ alcohol-soft.com -
Thank you for your responses.
But I don't think I can use any of these programs in conjunction with Fireburner, which is what I'd like to do... I guess I'll just have to wait until I get more CDs. :3
What exactly do you need to use fireburner for?
If it's to burn an image, you can just mount the image with daemon tools.. it'll be as if you burned it to a CD and put it in a CDRom drive.
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 16:31 -
burn vob into cdr
By pcb in forum Newbie / General discussionsReplies: 10Last Post: 18th Feb 2008, 12:28 -
VIDEO_TS on a CDR?
By kippard in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 05:20 -
.cdr file on a DVD+
By jamesmarcustucker in forum Video ConversionReplies: 1Last Post: 6th Sep 2007, 07:13 -
DVD Media... NO CDR!
By Lighters in forum MediaReplies: 5Last Post: 5th Jun 2007, 11:26
