Hi
I read through some of the posts here concerning Svcd's and I've just come across my first which just won't play correctly on my PC at all.
I've tested the following:-
Cinematograph (v2.1.2.0) - Doesn't play, cd spins but no picture or sound, and no error
Windows Media Player 7 (v7.00.00.1440) - Doesn't play, error is "No combination of filters could be found to render the stream"
Windows Media Player 6 (v6.4.7.1112) - Similar message to v7 but after a rebooting and installing *something*, when I run it a message appears saying "A required .dll file Msdxm.ocx was not found"
WinDVD 2000 (v2.0) - Plays but no picture, only sound
The above seem to produce the same results, regardless of whether I have the mpeg-2 codec installed which Stinky very kindly sent me.
Other related Items I have installed for other things are the Divx 4.0 codec, which also installs *The Playa* and a *Divx Validator*. The other related item I have installed is the *nAVI Vx3 MPEG-4 Codec (smr patch)*
I copy and pasted the info from the Information window within Cinematograph incase it helps:-
Cinepak Codec by Radius
Direct Runtime Dvd version 6.3.1.400
Direct Runtime Quartz version 6.3.1.400
DirectX version 8 or better
DivX Codec 4.01
Indeo video 5.04
Intel Indeo(R) Video R3.2
Microcrap MPEG-4 Video Codec V3
Microsoft H.261 Video Codec
Microsoft H.263 Video Codec
Microsoft HLE
Microsoft Video 1
I'm using WinME, AMD K6-2 400mhz with 128MB which I think should be able to play it fine. Divx and Vcd's are normally ok but after a read it's most likely to be down to the mpeg 2 thing but I don't know what.
If anyone has any information regarding this I would be most greatful as I can usually get my head around these types of things but this one has me stumped! Members here know a hell of a lot more about it than me so I thank you in advance for any advice you might give
[EDIT]
I forgot to mention that I also tried to view it from within TMPGEnc and nothing happened, no picture or sound and no error.
The file information is:-
F:\MPEGAV\AVSEQ01.MPG (F: Being the CD-ROM)
805 MB (844,774,940 bytes)
[/EDIT]
<font size=-1>[ This Message was edited by: AP0ll0 on 2001-10-19 13:49:24 ]</font>
Results 1 to 1 of 1
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
svcd will not launch.
By hawkwind in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 17th Jan 2009, 18:09 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
