I have recently purchased my first DVD player - We have three TV's in the house which are all networked to a satelite receiver and a video player - I was hoping that I could also connect my DVD so it could be viewed on one or more of the TV's - To try and achieve this I connected my DVD to the Scart socket on the Video recorder this works fine on some DVD's but not on others were the picture and sound is distorted, however if, for these DVD's, I connect the DVD directly to the television the distortion does not occur and the DVD plays fine unfortunately when I connect up this way I am unable to network the DVD signal to other TV's.
Anyone have any advice - Thanks
unfortunately you have encountered macrovision protection. there are several ways around this problem.
1. macro disable via a hack which possibly is on this site somewhere
2. a anti macro device such as a sonel mac master or the bug blaster box
3. play back ups only with the macro stripped!
hope this helps
cheers
Malcswhat comes around goes around
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 13:11 -
DVD Player crashes when playing dvd with vietnamese subtitle
By ssalim in forum SubtitleReplies: 0Last Post: 28th Apr 2010, 15:52 -
Playing region free DVD on Sony SR200P DVD Player
By merik in forum DVD & Blu-ray PlayersReplies: 5Last Post: 25th Nov 2009, 15:35 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37 -
WinAVI Video Converter 8.1 (DVD gets stuck while playing on home DVD)
By Zuzuu in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2007, 12:37
