usally i frameserve with virtualdub in tmpgenc.
i want to try something else.... i have a xvid file with ac3.
i want to use mainconcept encoder because tmpgenc dont accept the ac3 audio file,and mainconcept accept it...
i dont want to extract the ac3 file to wav or something else...
so i tell you wath i did
i frameserve subtittle's with virtualdub in mainconcept....and i get a green picture
is there a way to do this...or wath settings i have to use....
i did the file (xvid with ac3)...without frameserving and everthing is perfect
so there is no problem with xvid codec
yes he did it....i mean the ac3 audio file
it think it is mabie een good setting?
but my problem is i think also een setting problem -
I was able to frame serve to a demo of Mainconcept 1.4 using VirtualDub... I just gave the frameserve file an .avi extension instead of the default .vdr.... It worked fine...
If you want to try another encoder otherthan TMPGEnc then why not try CINEMA CRAFT ENCODER ?
I say this because CCE BASIC is only about $70 USD yet it is often times considered the best MPEG encoder out there.
Something to consider especially since MainConcepts is about twice as much as CCE BASIC
I think I missed the obvious earlier - if you install the Ac3 ACM decompressor then VirtualDub should work as a Frameserver to TmpgEnc.
Could be proved wrong though
Creative Media Format (.CMV) proof-of-concept encoder
By plexx in forum ProgrammingReplies: 8Last Post: 15th Jul 2011, 16:13 -
main concept's cuda encoder released to public
By deadrats in forum Video ConversionReplies: 1Last Post: 17th Oct 2010, 19:33 -
Main Concept Pro HD4 work in CS5?
By darkztk in forum EditingReplies: 2Last Post: 6th Aug 2010, 23:00 -
main concept gains gpu accelerated encoding
By deadrats in forum Latest Video NewsReplies: 0Last Post: 5th Jun 2010, 16:19 -
main concept no audio source
By petemacc in forum Newbie / General discussionsReplies: 4Last Post: 27th Aug 2007, 15:22
