I uninstalled svcd2dvd 1.5 by mistake and need to reinstall it.
When i go to user area of web site it asks for a serial number which i cant remember and when i click on cant remember serial ir just refreshes and i dont get anything sent?
Please help as i need to reinstall asap
i have emailed the site as well.
Cheers
Chrissyboy will get round to replying will just take a bit of time....
As a good measure it is always worth printing out emails with any registration details in them so you have a hard copy incase you have to reformat and forget to back up or dont bother to save the email in the first place.Not bothered by small problems...
Spend a night alone with a mosquito -
I have now managed to get it to email me my serial number but now it says i have used my 2 licences
Ok as it says on the site you will have to email Chrissyboy and wait for a reset of your counter.
Why not use Restore on XP, go back to a time your serial number was in the registry & see if that works.
Good idea my man...Originally Posted by handyguy
It is sorted now but i coiuldnt use system restore as i had it turned off
MPC-HC upgrade a mistake?
By Monarch1st in forum Software PlayingReplies: 10Last Post: 26th Feb 2012, 15:24 -
Office 2007 can't be uninstalled
By ukb007 in forum ComputerReplies: 3Last Post: 15th May 2011, 10:51 -
Media Centre CyberLink programs accidentally uninstalled- please help!
By Joanna in forum ComputerReplies: 7Last Post: 16th Nov 2007, 14:24 -
mistake after burning
By gastzugang in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 15th Sep 2007, 15:43 -
Mistake to buy a standard definition TV?
By LT9000 in forum Newbie / General discussionsReplies: 39Last Post: 28th Aug 2007, 10:39
