Appreciate if anyone can help me on this.
The VCDs that i create are not playing on my Sony DVD player (DAV-S300). It shows "no disc" on the player.
FYI
I am using the following hardware:
a. PIII 800MHZ(intel), 160MB RAM, 20GBHDD, Live Soundcard,
b. DVCII (by dazzle) for capturing...with Movie Star software
c. ACER CDR-WR for writing/burning on CDRs
d. Nero for creating the VCDs (using the wizard to create VCDs)
I capture the videos by using the VCD template available in the provided software (Movie Star), then produce the captured mpg into VCD format , then finally use Nero for burning on the Acer writer.
Eagerly waiting to hear from you....
Results 1 to 9 of 9
It sounds like a media compatibility problem... If you burn an audio CD on the same brand of CD-R, does that play in your DVD player?
Try another brand of CD-R media or CD-RW media.
Regards.
Michael Tam
w: Morsels of Evidence -
I have exactly the same problem with a Sony DVPS335
The laser will not read any CDR media i have tried regardless of what is burned on it Audio or Video.Sony tech line state that CDR`s & CDRW`s do not reflect enough light for the laser to read them.If you find out anything else please let me know.
Regards
Alan -
Regards
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Try Memorex Platinum CDRW, This one should work
I have the same player. I think you have a media problem, Sony will play only CD-RWs properly and not all CDRs.
Many thanks to all who have contributed towards this and helped me resolve this problem.
I have finally made a vcd on a CD-RW (ACER) and is now working fine with my DVD player.
Guest
So you copied your other cd-r's to Acer cd-rw and it works fine wtih your Sony DVD player now? I have a Sony DVP-7000 and someone made some vcd's for me on cd-r media and it will play the picture but no sound. It works fine on my computer though and my friend said it worked fine on his Panasonic DVD player. I was just wondering if I copied the vcd's to some other cd-rw's if it would work? Any thoughts?
Try the princo cd-r or the sony cd-rw those have worked on mine, although some of the princo vcds that i made became coasters. All of the sony cd-rw vcds have been good
Sony CD-RW650's don't work in my dav-s300. Not VCD or Audio, Should I try Princo?
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12 -
Sony DVD dav-fr1
By Gerard Russell in forum Newbie / General discussionsReplies: 1Last Post: 16th Nov 2008, 00:55 -
Need help unlocking Sony DAV-DZ150k dvd player - pls & thanks 4 help!
By Aussie Gal in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Jun 2008, 03:17 -
I have a Sony BDP S300 BluRay player, and the menu
By tzm in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Mar 2008, 03:20
