Bought a 5-pack of TDK DVDRWs which, predictably, don't work (it can't read them)
Any ideas which DVDRWs might work??
Andrew
Results 1 to 10 of 10
I have a Philips 985. Memorex, HP, Fuji, Optodisc, Philips, and several others, all work. I have never had a problem with any +RW brand that I have tried.
What do you mean by "it can't read them"? Does it say "no disc" or some other error when you put the disc in? -
Yeah, it said "No disc". Is this probably, then, a case of an incompatible DVDRW as I hope or some sort of error with the DVD Recorder. Might I have more luck with DVDRs??
Andrew -
If you try to load a -RW (instead of a +RW) it will say no disc. Where were the TDK's made? Those made in Japan and Singapore are fine, but the ones made in Taiwan can be a bit unreliable.
I've used TDK (made in Japan & Singapore), Verbatim, and Imation. No problems in the DVR75.
Andy. -
Yeah, it's a DVD-RW, not a DVD+RW. Whats the difference?
Andy
PS: Yeah it's from Taiwan! -
the difference is your phillips is a +rw so there is no chance you can record onto a -rw it will play them but not record on to them
Yep, you can only record onto +R/+RW discs as the Philips isn't a multi-format recorder. I've found in the past that TDK's made in Taiwan can be unreliable (in other +RW recorders at least). I've also found the same thing with +R TDk's made in Taiwan on the Panasonic E20. Just check where they're made before you buy.
Andy. -
Thanks guys!
I reckon there should be a link to this forum instead of a technical support phone number. Costs a lot less (obviously!), you get friendly support and
above all a fast response!!
Andy (or Andrew there r two of us here at least!)
How to make USB video work on Philips LED series 6000 TV
By Joaquim Brasil in forum User guidesReplies: 3Last Post: 14th Sep 2013, 15:58 -
Philips 5992 DVDP?? Upgraded Firmware but H.264 doesn't work?
By sandman423 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 24th Dec 2008, 10:09 -
Trying to convert MPEG2 file to work in a Philips 5980 DVD player
By JohnWB in forum Video ConversionReplies: 3Last Post: 31st Mar 2008, 08:16 -
Philips DVP642 DivX subtitles. WORK!!!
By shrybouski in forum DVD & Blu-ray PlayersReplies: 22Last Post: 7th Aug 2007, 15:06 -
Philips DVDR7310H: search (Guide Plus) doesn't work anymore
By Monco in forum DVD & Blu-ray RecordersReplies: 1Last Post: 6th Aug 2007, 13:05
