I've been using Microsofts DirectShow filter graph builder.
Trying to connect together codec to do video conversions of avi to mpeg.
Any one had any luck doing this? Seems like an nice easy way to put things together.
Hmm...Seems very geeky and interesting.
I'm stumped on how you can encode MPEG video/audio via Directshow filters? What Directshow based MPEG encoder are you using? YMPEG? When I installed Sonic MyDVD version 4.0 and ran 'sysenum.exe' tool I saw that some Directshow based Ligos and Mainconcept MPEG encoders were in the list.
Hhmm. -
well most of the software I've installed is installing these codec.
and you can use them from the filter graph.
Its really quite simple... Till things go wrong.
Which is the best direct show FLAC decoder?
By gOdiSOnyOuRsIDe in forum Software PlayingReplies: 7Last Post: 11th Mar 2012, 10:33 -
Direct TV/HDTV Signal Question
By RKelly in forum DVB / IPTVReplies: 5Last Post: 12th Mar 2010, 01:55 -
Direct Cable Or Digital Converter Box, quality question
By allthumbs in forum Capturing and VCRReplies: 20Last Post: 3rd May 2009, 21:55 -
Play mp4 file using direct show
By kalpanaanb in forum ProgrammingReplies: 3Last Post: 3rd Apr 2009, 07:45 -
direct Tv question and tv tuner
By mohz in forum DVB / IPTVReplies: 3Last Post: 6th Jan 2008, 21:35
