I have a divx file I'm converting to mpg to burn onto a DVD.
The video is 720 x 288 (x:y)
When played as a divx file has the proper aspect ratio.
ie its very wide. I'm not sure if its 16:9 or 2.21:1.
So.. I converted it to MPEG with Mainconcept's mpeg encoder.
(Set to produce DVD)
After the conversion was complete the image looked very square
(more like 4:3) than the original wide screen divx avi file.
What did I do wrong?
I see in the Mainconcept's advance settings a setting for aspect ratio,
but the only options available are 16:9 or 4:3. 2.21:1 was not selectable.
When I measure the video on my monitor (as rendered by nero showtime)
the video is about 19.6x X 8.3y. For an aspect ratio of about 2.21:1
So why can't I produce a 2.21:1 mpeg with Mainconcept?
These are guesstimates...because I am not familiar with Mainconcept, but I am familiar with DVD aspect ratios and TMPGenc.
Did you do this...?
You can try to resize the 720x288 to 720x480 and apply a wide-screen aspect ratio like 2.21:1 whilst encoding to MPEG-2. So the actual number of pixels in the video will be 720x480 but the applied aspect ratio will change the effective size during playback.
If only the height changes during playback: 720x326 = 2.21:1
If only the width changes during playback: 1060x480 = 2.21:1
Aspect ratios info:
http://www.dvddemystified.com
https://www.videohelp.com/forum/viewtopic.php?t=202215&highlight=dvd+aspect+ratio
http://mornmist.2y.net/~blibbler/tutorial/other/aspect.html
http://www.mir.com/DMG/aspect.html
http://www.widescreen.org/aspect_ratios.shtml
...there are more results on Google.com...
Well, that's all the rambling babbel I can write now... -
In Mainconcept, open your avi.
Select DVD for output.
Click the DETAILS button.
Click CROP & SCALE
Set the height and width.
In your case, a 16:9 original should have an output of 720 x 480.
If you find that those settings are making it look like 4:3, then cut the height down to 360. This should give you an output that's the same aspect as the input, and still be DVD compliant.Cheers, Jim
My DVDLab Guides
Aspect Ratio Question
By rede96 in forum Newbie / General discussionsReplies: 5Last Post: 14th Aug 2011, 05:17 -
Aspect Ratio Question + Some
By Alexander4444 in forum Video ConversionReplies: 7Last Post: 9th May 2011, 03:17 -
By kelticvixen in forum Newbie / General discussionsReplies: 3Last Post: 12th Jan 2009, 14:27 -
aspect ratio question
By brianhj in forum Video ConversionReplies: 6Last Post: 16th Aug 2008, 13:54 -
Aspect Ratio Question (Sorry!)
By rede in forum Newbie / General discussionsReplies: 12Last Post: 30th Dec 2007, 08:25
