Hi, I have a few mpegs that I'd like to remove part of the background or make it black. No cutting/joing, more like just editing the original video clip. What program works the best? I couldn't figure it out in Adobe Premiere. Thanx for any help![]()
so you want to black-out some of the background....let me guess.....in the background is either your mother-in-law or Ron Jeremy....?
anyway, if what you want gone is around the edges you may be able to delete by using a crop function available in several different editors.
Also....if the unwanted video object/s remains in a relatively static position throughout the video, you may be able to censor with some type of block editing function.
However, if what you want gone changes shape and posititon I suspect removing it may be rather complex. I'd anticipate an expensive editor and a steep learning curve. Maybe it's simpler then I think.
Perhaps it's easier to approach it from what you want to keep rather then what you want to eliminate. -
I suppose you could open it with Virtualdub-mod and use something like Delogo or Logoaway filters, then frameserve to TMPGEnc for conversion back to mpeg. Logoaway will insert a coloured box or a "fuzzy" box over anything you like. It is static though and it's rectangular only. You could cut/clip at the same time.
"Art is making something out of nothing and selling it." - Frank Zappa -
Well, I have After Effects and Premiere (don't know how to use them effectively though)
I don't even need to really remove it; perhaps just black it out some way...
What do you use to clean your system?
By Banleno007 in forum ComputerReplies: 4Last Post: 17th Feb 2012, 19:51 -
Is there a program to clean mp3 file of torrent traces?
By aqualung2003 in forum AudioReplies: 3Last Post: 1st Jun 2011, 01:29 -
Too many codec, how do I clean up?
By cheerful in forum Software PlayingReplies: 7Last Post: 17th Jan 2010, 22:36 -
Is there a program like DBAN, that can wipe external hard drives clean?
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 19th Nov 2008, 03:34 -
MPEG1 Editing Program?
By MindF in forum EditingReplies: 3Last Post: 2nd Apr 2008, 14:28
