i have a movie which is on a 700mb cd.its burnt as data,when i copy it on to my pc its fine.but as soon as i try create a vcd with it,i drag it on to nero and it expands to like 3000mb in size.how can i fix this? pls help![]()
truly, you havn't given nearly enough information to receive a very helpful answer. You need to be more specific and descriptive.
I'll take a couple of shots with the info you have given:
You said avi on a data cd so I'm guessing a highly compressed movie. Probably a DivX or XVid encoded video.
If you are truly trying to somehow plug it into a VCD template in Nero and getting an estimated 3GB product, then the movie has to be approaching 5 hours in length....doesn't seem very likely.
However, if you are trying to slip it into a DVD template, then a 3GB taeget is more plausible....especially if the movie is much closer to 1 hour in length.
You need to to start reading the information in the column to the left of this page starting at the glossary. -
i said everything i know.the movie is avi.i burnt it using nero and burnt it as a data cd.the data cd is 700mb.i now want to take the movie from the 700mb cd and burn the movie as a vcd,but every time i drag it from the 700mb disk on to nero it suddenly expands to like 3000mb.the movie is only an hour long.i dont understand what other info i can tell u.
ok then
my guess is you're plugging it into the dvd template of Nero rather then the VCD template. 3 gb for about 1 hour is around the right file size for a high bitrate DVD.
Cannot get trimmed a DV-AVI movie in MS Movie Maker
By askmaxim in forum EditingReplies: 0Last Post: 30th Dec 2008, 06:44 -
Videos expands off screen
By Squid_uk in forum Newbie / General discussionsReplies: 13Last Post: 15th Sep 2008, 19:40 -
Does anyone know? Some AVI movie files do not convert through Nero
By lisajustin in forum Newbie / General discussionsReplies: 2Last Post: 3rd Dec 2007, 06:54 -
DV-AVI widescreen 16:9 movie from Windows Movie Maker.
By bagb in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2007, 11:37 -
resolution on movie nero digital
By krain_l in forum Newbie / General discussionsReplies: 3Last Post: 25th Jun 2007, 00:49
