Please someone help! I have done converting divx movie to 2 separate files of m2v(video file), and the audio (mp2). Now I made my own dvd on sizzle and saved it as an image and tested it on my mac dvd player and the audio is ahead of the video... Please help!!
Thanx,
Vin
I used Mpeg2works 3.3.3 used the DVDNTSC 16:9 feature to convert my divx movie to two separate files of Audio(mp2) and video(m2v)...
that app should have give you a synced mpeg file in addition. The .m2v and .mp2 are the temp files.
look around for the muxed mpeg file and test its sync
ive done LOTS of divx to dvd with this app and never had sync probs in the full muxed mpeg file -
Yes it does you are right but when i play it, it also delays, even sometimes the original divx movie. But then after i fastforward or rewind the divx movie the delay seems to go away... anyway to fix this?...
ummm......... what kind of mac do you have? Mhz wise?
if the origional file has problems like this its not possible to use mpeg2works to get a synced final result.
you "may" be able to open the mpeg in something like sync hole and correct the sync but problem is it only saves to .mov -
Plus i also downloaded the divx movie more then once, possibly 4times and the audio still delays....
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Audio video sync problem
By FrankieToh in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2010, 08:53 -
I Give Up. Can't Burn AVCHD DVD Without Audio Being 4-5 Secs Ahead of Video
By bmccollum in forum Authoring (Blu-ray)Replies: 8Last Post: 21st Oct 2010, 09:32 -
Audio Video Sync problem
By m baqar in forum Authoring (DVD)Replies: 1Last Post: 27th Mar 2008, 01:59 -
Audio/video sync problem
By Hekey Williams in forum DVD RippingReplies: 1Last Post: 8th Oct 2007, 05:27
