  1. I captured VHS tape and audio is mono appears
    only in one channel. I have plenty of other tapes I want to capture
    and looking for advise - what tools can duplicagte audio to both
    channels without going thru much hassles.
    Apr 2002
    The State of Frustration
    Load the the captured video into Gold Wave. Select New-->Stereo-->Proprer sampling rate-->and length equal to the video. Select OK.
    This will bring up a blank video file. Copy the original video and selct the new video. In the new video select Edit-->Mix.
    Save the new video as a wave, it will now consist of your old audio from your original video in stereo format.
    Hello.
  3. Does TMPGEnc has same option in MPEG DMUX?MUX section ?
    Apr 2002
    You can separate the audio from the video, but actually making the mono into stereo, I have no idea.
    Hello.
  5. Member Roderz's Avatar
    Jul 2003
    the armpit ofthe Midlands
    demux file
    run soundforge -> new file (stereo 48kb bla bla bla.)
    load de-muxed audio into sound forge - select all of track and paste into new stereo file (twice, 1 in each channel) save new file, remux!!!.
  6. Member Deekkeed's Avatar
    Oroville,California
    To save time with future captures, you could get your self an RCA Y Adapter and split the audio.
    Apr 2002
    Some capture cards have only one audio in channel, and some programs only capture in mono.
    Hello.
  8. Member Deekkeed's Avatar
    Oroville,California
    Sorry, I guess I was not thanking.
