I am using DVDXCopy Express and have encountered a few problems. When it comes to drive select theres nothing in th drop down menu. I have removed and reinstalled both my dvd burner(8x BTC dvd dual) and my dvd rom, but still nothing. I even went into device manager and removed them there and have reinstalled DVDXCopy Express on numerous occasions. Please someone tell me that they had the same problem and how to fix it.
I am running Win 98SE
This is a strange problem i Guess you place a disk into your drive and run the movie to make sure it plays ok then open dvd x copy express
but if that fails use this linkhttp://forum.321studios.com/?f=48&m=6148&g=6154#m6154
this is the help forum of 321 studios the makers of your software search the site for a soluction to your problem as
I had a problem With DVD X Copy Platinum When I first got it
And This Site Sorted It One To Check Is Conflicting Software That Is Know to Cause problems With Dvd x copy All Versions
Hope This Helps
Black Magic Media Express Problems
By Decerto_LethaL in forum Capturing and VCRReplies: 0Last Post: 13th Dec 2011, 10:39 -
Problems writing with nero vision express 3
By tatester in forum Authoring (DVD)Replies: 3Last Post: 11th Feb 2009, 17:38 -
Express
By webmaster P in forum DVD RippingReplies: 0Last Post: 20th Jan 2009, 22:27 -
Outlook Express problems
By rhegedus in forum ComputerReplies: 6Last Post: 16th Apr 2008, 18:07 -
Problems with Pal-60 capture using ATI AIW 2006 PCI express Radion X1300
By DB83 in forum Capturing and VCRReplies: 2Last Post: 6th Aug 2007, 17:49
