Trying to get a losses dv capture that I can convert with virtualdub and dvdtosvd. I have windows xp pro and a firewire link. I have tried the following so far:
Windows Movie Maker- DV NTSC can play can't convert even after getting canopus codec and file converter and using.
PIXELA - Bad program ame with camera as two formats mpg1 (poor quality) completely uncompressed dv works but a little hudge.
Powerdirector Pro OEM version - not bad but no lossless compression that I could find.
DVIO - can play can't convert even after getting canopus codec and file converter and using.
Thanks Mark
I haven't used Virtualdub for quite a while now, but I have a feeling that it can only cope with Video for Windows format files. DV transfer is Directshow format,
I think I've seen some mentions of a plugin for Virtualdub and no doubt someone will tell you what you need to know. -
Panasonic DV codec will allow vdub to open DV avi files.Originally Posted by Richard_G
Use DVIO to capture to type 2 avi.
DV is ~13Gb per hour of video.
Capture...convert...confused!!!
By cyber-junkie in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2010, 14:11 -
HD Capture - Any way to convert from 1080p60 to 1080p24?
By Corvius in forum Capturing and VCRReplies: 4Last Post: 8th Nov 2008, 07:16 -
Sporadic signal losses while capturing analog gaming footage w/ camcorder
By Nintendo Fan in forum Capturing and VCRReplies: 0Last Post: 17th Oct 2008, 19:45 -
DVI losses connection after input switching
By Daft in forum Media Center PC / MediaCentersReplies: 3Last Post: 5th Dec 2007, 14:05 -
NLE DV with WMM? Any losses??
By towtruck in forum EditingReplies: 32Last Post: 3rd Jul 2007, 17:50
